Discuss Wall Chaser in the Electrical Tools and Products area at ElectriciansForums.net
B
bradders
I am considering buying a wall chaser and am confused with what is on offer?
At the risk of appearing stupid can someone tell me what the point of a wall chaser that cuts to a maximum depth of 30mm is when T&E should be 50mm in the wall? Unless of course the 30mm is considering dry lining/plastering adding to the depth. Not much use for a rewire though.
Cheers
Brad
T&E only needs to be chased into a wall to 50mm to eliminate the need for additional protection by a 30mA RCD.
Absolutely in a domestic situation everything will have the beloved RCD protection so don't worry about the depths of the chases.
What? A channel 50mm by 30mm will cause structural problems! Do me a favour!
Yes. Get yourself a copy of the Electrician's Guide to the Building Regulations. In my copy, published 2005, section 10.1.2 says maximum depth of vertical chase to be one third of wall thickness and for horizontal chases, one sixth of thickness. So, for a nominal 100mm block, 33mm vertical and 16mm horizontal. (I'm guessing plus depth of plaster, since the plaster's not structural!)
Reply to Wall Chaser in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
Hi all! Be gentle as this is my first post on here. I am looking to buy a wall chaser but the cutting width is only 30mm max. The 25mm PVC...
10K
I seem to be getting more rewires than usual and am considering buying certain tools that aid rewires as they are bloody hard work. At present I...
10K
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I've have had a lot of experience of "DIY house electrics" (changing sockets, adding sockets, lighting circuits etc.) over many years but what...
