Discuss Wall Chasers in the UK Electrical Forum area at ElectriciansForums.net
davel81
Hi
I am in the market for a wall chaser. Recently started out on my own, so finaces are limited!!! Could anybody recommend or otherwise anything on the market.
I'm in the market for a decent chaser too mate. If you search I'm sure there are a couple of threads about it already.
Definitely don't go for the cheapest you can find (no "Titan" tools from Screwfix or the like for this one!) I've seen a couple out there from top brands (Bosch blue, Sparky etc) but have yet to make my choice.
Why not Titan?
I have my house to wire in a month or so and need something to chase the walls with.
After all I will probably not use it again... So a 1500w sds should do the job shouldn't it?
Had an Euraber from Screwfix which broke after a year. Now have a Sparky ( for 2 years ) and still going strong. Use a Henry for dust extraction which works well.
Reply to Wall Chasers in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I am getting ready to install a new wall oven that's about 4 ft closer to the panel than the old stove. I have about 4 ft extra cable with the...
Quick question to electricians - I want to add metal-plated sockets to newly plastered walls. The electrical wholesaler advised that newly...
