Discuss Wander leads in the Australia area at ElectriciansForums.net
F
flukeyspark
Hi,
Is it worth buying a wander lead or is it best making one from an extension. Its just that I have my NICEIC inspection coming up & I dont want to slip up-you know what there like!
Thanks............:confused:
Makes no difference, aslong as it is nulled or it resistance subtracted from the final result then its ok. I just used and old coil of thin insulated wire i had for electronics, crimped a banana plug on one end and a croc clip on the the other to make it easier to work with
Hi,
I think an extention lead might be a bit bulky.I would use single(conduit cable)2.5 or 4mm,keep it stored on the coil--and as paul says make sure to null the lead or else subtract its resistance from your readings.
The wander lead method is probably the best method for checking continuity.
However, you do not need to have a dedicated lead. Roll of single will suffice with it nulled before you test.
Thanks for that. The cost of wander leads is crazy, about £70.00 for a kewtech........Thanks again
On the subject of assessment, is it essential to have amp clamps, proving units & lock off equipment etc?..........
Reply to Wander leads in the Australia area at ElectriciansForums.net
Hi Guys, just looking for a bit of advise. I am booked up to go on 2391-52 soon, and was looking at using my own tester, Megger1552. It is all...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi guys and gals, I have a question about the leads to computers (commonly known as kettle leads). I am new to PAT testing so please bear with...
Hi So after working for a company i have decided to go self employed and start my own business. people on checkatrade my builder and rated...
