We had our kitchen done 5yrs ago and we've just had to replace our Tumble Dryer and found that there is a double socket under the sink that supplies both the Washing Machine and Tumble Dryer.
It's worked fine for 5yrs, but it was highlighted by the guy that installed it (part of taking the old one away) that it wan't "ideal".
There's conflicting stuff on the net about this, so just thought I'd post for a bit of clarity?
From my research, double sockets are rated up to 20 amps for a minimum of 4 hours. I've checked the wattage of both appliances and converted to amps as follows:
Washing Machine = 1600W or 6.96 amps
Tumble Dryer = 2200W or 9.57 amps
Does that mean with both appliances on at the same time, the max draw would be 16.13 amps and well within the 20 amp rating of the double socket? Notwithstanding that the Washing Machine will only draw max power for 15/20 minutes of each wash?
Just to be safe, we are intending not to run the both of them at the same time, but would be "safe" in any event?
