The Copicat design was done back in the day when avoiding signal earth loops between equipment was perhaps more significant than providing a safety earth. The earth was intended to be provided via the signal lead to the amplifier.
If you introduce a direct ground connection you will likely introduce more mains hum.
One way to provide better safely I've seen, is to add a mains isolation transformer at the incoming mains to the Copicat, (for electrical safety) and then make sure the signal lead between the Copicat and amp have good ground connections, and the cable is low capacitance (as the Copicat o/p impedance is v high)
The question is whether the problem noise is actually generated by the Copicat, or if it's already due to an earth loop somewhere.
