Search the forum,
Discuss What forms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Had a job to do go that should of been simple. Replace two broken sockets, change a single socket to a double and change two duff downlight transformers.
The home owners had had a conservatory added about 5 years ago. One of the sockets to change was in the old house, it was on the ring but the line was broken. The other socket was in the new conservatory. All the sockets in the conservatory had no earth. What the F. Amazingly, what had happened was that someone had extended the ring into the conservatory from a socket in the original house. They had extended the line and neutral but had messed up with the CPC. They connected the CPC such that the original house CPC ring was in tact and the conservatory had its own CPC ring but not connected back to the CU. An easy fix once found
As for the broken ring on the line, I narrowed it down to a cable between two sockets. So after agreeing with the lady of the house, this cable was disconnected and i swapped the MCB from a 32A to a 16A (couldnt use a 20A as the Zs was too high). So i filled out a minor work cert, job done or so i thought. Question 1- is this notifiable?
I then received a phone call from the lady of house telling me a socket doesnt work. So i go round there and the man of the house shows me this socket that is hidden (the lady of the house didnt know it was there). To get to it you have to take some drawers out. I did ask the lady of the house several times if there were anymore sockets when doing my tests to find the lack of earth and the break on the ring. The owners are lovely people and are quite happy to pay me to fix this problem in additional to my original bill. Now if the broken ring is not to do with fixed wiring but due to a loose connection in this socket (which is loose on the wall) then i can re instate the ring, put the 32A MCB back.
If this is the case should i issue my original minor works cert and then issue another for the now upgrade to 32A mcb or should i scrap the first and just issue a minor work cert for replacing the 2 broken sockets
I'd scrap the first one as you have reinstated the circuit back to it's original installation. Make a note of problems found and any remedial work carried out, just cover your arse basically.
Don't listen to me. I'm a Electrical Trainee and don't know what I'm talking about. :lol:
Forgive my ignorance but what is a Electrical Trainee? As for the question I would only issue one certificate once the works have been successfully completed, and always remember any fault can be found and rectified providing enough testing is carried out.
It has become the shortened way to call someone who has been on a 5 week course and been let out as an 'electrician'
5 week wonder
Oh dear, I have heard the expression but failed to put the phonetics together, thanks for the reply.
Yes, we're dangerous and shouldn't be let out unsupervised... :reddevil:
It took me more than 5 weeks just to revise for some of my examinations, and my papers took double that to prepare!
Has for being dangerous I very much doubt that providing you apply what you do know and learn to acknowledge any limitations.
Otherwise I doubt you would be on this forum, the dangerous ones are those under the radar.
Reply to What forms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hello all. I have just bought my first house but it needs a bit of work. I am re-wiring it and I've found the conservatory ring has been spurred...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
