Discuss What is AMF? in the Canada area at ElectriciansForums.net
what's function of AMF?
A little more detail would be helpful, but I'de guess your talking about "Automatic mains failure". So this would involve an automated back up system i.e.-
Generator or Battery backed up in the case of a mains failure !!!!!
backed up ... so it can use high voltage device for back up? anyway can u give me link how to study that device for trouble shooting.. thnx
Impossible for a link, far too many different scenarios, amf means - auto mains failure - depending on what your automating makes a big difference.
The device is quite simplistic, you can auto change milli volts or 1000's of volts, but don't get the two mixed up!
Normally speaking, it means swapping like for like, like a genset or battery backup.
Where the coil is fed n/c or sometimes n/o, if normal power fails then the contactor drops in (or out, if backed up).
Which in turn sends a signal to the backup power source, to either start or cut depending on the configuration. AMF contactors usually means neither can be functional at the same time, mechanical and electrical safety devices makes that impossible, you have one or the other, never both at the same time. In the normal everyday world amf is usually associated with mains generators but it can be used in pc logic
Oh dear, I rest my case with supposed ' Electricians Forum'. some guys are helpful -;) but in all honesty why did you post here? Are you a 'tester' -:)
Reply to What is AMF? in the Canada area at ElectriciansForums.net
Hi, agricultural off grid project, Victron inverter/charger, BYD LVS and Pramac GBW22P generator. The generator has a DSE4520 controller...
Evening all, I've been asked to install a generator backup to a property, however they are going to be using a AMF panel. The generator they are...
We are a UK registered Electrical company with a large contract based in and around Toronto, Canada. Are you looking for work? We have a...
Do the forums cover electrical systems in the UK, Ireland and EU countries or are they only for US/Canada/North America?
I've lost touch a bit with permanent install generators and combined AMF controls over the last 3-4 years - what Manufacturers are people using...
