B
Borderssparky
Hi
can anyone tell me how old this is, eicr in an old property. Its been partially rewired in the last 20 years. It has a An old fuse baord with the asbestos flash fuses. Im getting a Ze of 25.5 ohms.
Is that still in service?
Age wise, look for labels on the fuseboard… there might be a year marked on it somewhere.
Partial rewire suggests some original wiring may remain. Old VIR? No cpc in lighting?
Whatever. An EICR is definitely going to bring up a number of non compliances…
Those ceramic inserts would have held fuse wire, the neutral has been bypassed by connecting direct to the base terminal. To say that is well beyond it's reasonable service life is an understatement probably been there since the 50s.
Lovely tiled floor.
I read that fuses in the neutral supply were made non-compliant in the late 1930's, so if it was ever fused, it would likely pre-date that. I think it's earlier than 1940!
The wiring regulations were up to their 8th edition by 1924! Started at the same cracking pace as we see now 🤪
