Discuss what meter tail cable-cpc? in the Australia area at ElectriciansForums.net
B
blenki
Hi im having to replace some old meter cable from the meter to the consumer unit , as it is around 6m in length i am going to fit a switch fuse unit , my question is what type of 25mm cable would you use and will it need a separate cpc other than the main 16mm main earth that is going to be run to the CU,also how would you wire it in , there is a double pole switch there at the moment so isolation shouldnt be a problem. Many thanks
Hey mate.
Is it a straight run to the C.U from the meter i.e up, down, sideways. Does it have to be concealed? can you use surface trunking? Also what size is the cut-out fuse??
If surface then 25mm tails with a 16mm earth in PVC trunking should be fine (depending on cut-out fuse). If you have to conceal then maybe an armoured or a concentric cable??
Spot on with the switchfuse if you can use tails then an MEM KMF would do if not, maybe a metalclad SF.
Cheers.
Hi lenny , the current cable is clipped up and along the cellar ceiling beam then up the side of the cellar steps to the top where the consumer unit is.The old cable is 10mm twin and what looks like 4mm main earth !
Cut out fuse says 100 amp but could be less , dont want to pull it
Hey.
As it's down in the cellar then no need to conceal I'm guessing...
Is there any risk of damage with the route being close to the steps?? If not then I would say that 25mm tails and 16mm earth in a surface trunking - MT4 or 5 would be fine.
Cheers.
Cheers mate , if i use metalclad il probably run the 16mm earth into the sw fuse and out to the CU , ive got part p assesment coming up soon so got to get it right:eek:
Reply to what meter tail cable-cpc? in the Australia area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hello again, Was looking at installing yet another dedicated consumer box for my EV charger off the henley blocks and i noticed that a meter...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Hi Guys Would I be correct in thinking an electric cable can be as close as 25mm to a gas meter ? (not that I'd ever be that close out of...
