In an ideal world you would build a ply wood mounting board that it raised off the buildings wall allowing all the cables to enter via the back of the cu so it maintains its IP rating. However each situation is different and i have many times mounted straight to the brick wall if cables emerge through the cavity
put it's back legs in your wellies so it can't run off. ( oops, mis-read CU as EWE)
Steer away from the cheap thin chipboard boards: they are so weak it is like trying to fix to weetabix. Oh, and use screws that are short enough not to stick out of the back of the board where they will pierce and snag the cables, and rip your hand to shreds if you try to fish cables around! This is a particular bug-bear of mine. Only yesterday I had to replace three cables that had been damaged by stupid oversized screws poking through 10mm out of the board.
