K
kevo201
Hi all,
I'm currently in my final year of my 2357 diploma, I have had no on site experience as I have been employed in a different industry for the past fifteen years. Due to this i am unable to do part-time/weekend work to cover the experience needed do the NVQ part of my diploma or continue on to do the am2.
What I would like to know is where this will leave me in terms of carrying out work and certificating it?
I know is something I should have been told by my tutors but every time a ask I never get a straight answer!
So if anyone has information that would help me, it would be much appreciated.
Presume they don't advise as its a bit of a grey area, from a 7671 point of view as long as you are competant then there's nothing stopping you setting up and sole trading as long as you register with a part p bod or notify council on job completion.
hope this helps.
@Johnuk. A different trade.
@AP Electrical. Does that mean I would have to have someone sign my work off? I would my certification be satisfactory enough as long as it was correct.
No decent spark will sign someone elses work off. If they are with you thorughout the job, then they may well do. YOU will have to join a self cert sceheme or inform your local Building Control of any notifiable work you complete (and pay their fees of course!!) as AP said above.
I don't think you have been on the 2357 diploma as it has not been around long enough for you to be in your final year and you would not have been allowed on it if you were not working. If you don't complete the whole qualification then you will only have finished units of it. Are you sure you haven't been on the 2330?
a forum for none electricians again, standards are so low, i spent years learning my trade, not worth it now standards have been brought DOWN to those of eastern europe, where you just turn up with a plastic bag with a screw driver in it and say i am a spark.
Really? That's not my experience of the trade, but there we go.
this guy has just asked what will he be qualified to do, just answer that if you can, if not dont bother flaming everyones posts.
As Votlz says they shouldn't have let you start the 2357 if you weren't working in the industry because you wouldn't be able to complete it.
In either case with the technical certificate you can work as a mate to complete the vocational parts, preferably full time, but I don't see why you couldn't do it part time and at weekends if you can find it.
Not sure that he will be awarded the technical certificate if he is on the 2357 Adam, because technically (no pun intended) he isn't doing that qualification, and will only get the unit credits towards the qualification. Remember when you did the technical certificate, you got the unit achievement certificates as well as the final one for the qualification, well at least I did. Bad that the college let the OP labour on under false presences if it IS the case that he is on the 2357. Maybe Kevo could come back on this thread and expand on where he is right now, perhaps we can help.
Yeah I got blue certificates for each unit and a red one at the end of the level 2, then another red one at the end of the level 3. Presumably if it is the 2357 the OP will get the same, which should at least be leverage to try to get work. Unless the college are really irresponsible and only after the money it sounds like this is the 2330.
hi i am currently in my second year on the 2357 and i started it the year it came out (i have been the gunnie pig for the course) this is the 2357 2nd year so how ia it you are on the 3rd year? not that i am questioning you or calling you a lier i was just wonderin.
i was told by my tutor that if we complete the 3rd year with out the 4th year which is the nvq side then we will be qualified to the same level as the 2330 level 3 technical certificate.
also i was allowed on the 2357 even though i was currently not working at the time but i think they have changed it now so you have to be an apprentice.
and in regards to the certificates i am on my second year and have completed all the units but i have still not receved any certificates as of yet
OP hasn't been back in touch so we are left wondering again. You have conformed what I speculated, that it is not possible to be on the final year of the 2357 when the qualification is fairly brand new.
