Discuss What's happening ? in the UK Electrical Forum area at ElectriciansForums.net
So the voltage drops when you plug into an extension lead connected direct to a DNO meter?
Who has given you permission to undertake something so reckless?
Are you actually a competent electrician?
A second glance tells me the earth is not connected, the meter terminal cover is missing and there is zero circuit protection. If you are are not an electrician then you are for want of better words stupid. If you claim to be an electrician then you are severely lacking in intelligence and competence with absolutely no regard for anyone's safety.
Come on OP, give us some more info. You can hardly say it's a complete post with only 2 words in it!
Well, that's a difficult one to answer.
If you guys are still alive then give us a bit more of an indication as to what you would like to know?
1 post. 2 words. Been on forum at least twice since but no reply.
Troll or time waster.
Reply to What's happening ? in the UK Electrical Forum area at ElectriciansForums.net
I was looking for the likes of the SQB1603K and see it is out of stock at CEF and no delivery option available. Odd. Then I search for the part on...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi all, We have a HV Schneider GenieEvo breaker, on the name plate, this device is rated for 50Hz. What would happen if we used a 60Hz supply...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
