Hi, Ive been asked to quote for running a supply to a garden office that will be pre wired.
Taking a supply from an existing supply in the garage.
Iam not sure what cert this will be and is this just a modification of the existing garage circuit or classed as a new circuit and notifiable.
Also whose responsibility will it be for the internal electrics of the office, will my responsibility for certs end at the connection I make at the office?
Thanks.
If you are energising it then it will become your responsibility to ensure it is tested and meets relevant standards.
Marston Moretaine, Central Bedfordshire
United Kingdom
Which Certificate?
Thread Tags
Tags Tags
certificate
Ajf100q,
cliffed,
