Discuss Which Wago for 4mm stranded in the DIY Electrical Advice area at ElectriciansForums.net
mikemel
Hi,
Have a question about wago connectors.
Looking for suitable wagos for connecting 4mm twin and earth stranded (7 strands), I already have some 221-412 wagos but on reading the specification it stated that they are suitable for use with solid and fine-strand 0.4mm to 4mm. If it is that they are only suitable for 4mm fine-stranded, which wago connector is suitable for the 4mm stranded?
It's for an existing 4mm twin and earth connected (internally) to 4mm SWA radial to the garage. The existing SWA is glanded to an old metal conduit box with the connection made with a 30 amp terminal block. I'm replacing the conduit box with a new junction box, using wago connectors for the connection.
Reply to Which Wago for 4mm stranded in the DIY Electrical Advice area at ElectriciansForums.net
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hi all, This weekend we have a selection of essential items for Sparky's on offer! Wago 221-412 2 Pole Compact Lever Operated Connector -...
My 1951 CA home (none of original wiring grounded) has 7 receptacles* that have a separate ground wire extended into the subfloor and connected to...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
  • Locked
5K
