Hi, as per the attached video clip, when I continuity test my windscreen wiper motor with a multimeter, it registers continuity between all 4 pins on the connector. The pins are for power, low speed, high speed and park.
Is this normal? It does NOT register continuity between the pins and the motor casing.
It doesn’t surprise me, however to find out if that is normal, you will need a meter to measure resistance and a diagram showing the internal wiring of the motor assembly.
Some way through the thread below are suggestions of how it could be tested (but for a similar, but not identical, motor). Keep looking!
Thanks, that was helpful
Adelaide
Australia
Business Name
n/a
Windscreen wiper motor
Auto Electrician Forum
Thread Tags
Tags Tags
None
kzlws6,
brianmoooore,
