Just looking for pointers, looking to do the donkey work before getting an electrician in to do the final bits.
Purchased a container block that came with a 63amp board inside, on the outside is a 100amp feed. What wire do I need to get this connected up? I've read that 16mm2 3 core armoured swa cable should produce about 99amps if above ground?
I'd be looking to connect this to a house 25/30meters max away from the container, the house isn't in use, it needs a fair few repairs but it has mains electric that work. Do I need to buy anything for the board inside the house? Does it require a fuse or a breaker?
Am I correct in thinking a 16mm 3core swa armoured cable will do the job?
If and when I have the correct wire, will that connect directly to the breaker on the outside of the container?
Finally, do I buy a grounding kit for this? The ground cable on the outside connects to the main board inside, which then grounds to the bottom of the container, is this enough or do I need a rod to go in to the ground?
The two pictures are of the board inside and the breaker outside.
I'd be running average appliance, I won't be having a washing machine or a tumble dryer, just things like an oven, electric hob, TV, ceiling light, the 2 heaters that are already in there, microwave, kettle, etc. Possibly an instant water heater for the dishes.
Thank you for any pointers in advance.
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of the Building Regulations.
Bude, cornwall
United Kingdom
Wiring a container
DIY Electrical Advice
Thread Tags
Tags Tags
wiring
lcs693,
westward10,
