i'm doing a rewire at the mo, the customer has said the plumber has asked if i would run a cable for the room stat while i was at it. will 1.5mm t+e do the job?
should i just terminate in a joint box as it comes into the old airing cupboard (where the boiler will be) and then run some heat resistant flex from there?
and not the porch where it currently is located...!!
