C
csm86
Hi, first time poster. I have been asked to wire a new build stable and was looking for advice on the earthing arrangements. Scottish power recently brought a PME supply to an external building, I then ran a 4 core SWA with a separate earth into the stables. However I have since found out that it is meant to be a TT system, is this correct? The stables construction is a concrete base with steel beams and between the beams are prefabricated concrete slabs at around 2 meters in height (if that makes sense). Does this type of structure still need to be TT'd? One last question (sorry for being long winded) the ground it is on is very rocky below the surface what would be the best way to drive earth rods into this if needed? Thanks for any advice.
