If you have problems like that with a multi tool you aren't using correctly, if you are bothered about a straight blade running away just start the cut with a half round blade and finish off with a straight blade.If you really don't want to use a circular box just drill the hole with the hole saw and then trim to square with the multi tool, better than trying to cut into the boards with the multi tool and running all the way over the next board when it runs away with itself, don't get me wrong I love my multi tool, but its not ideal for cutting into wooden boards, plasterboard yes its the perfect tool, but not for cladding.
While you might find it insulting from the negative comments you have made to date it suggests a multi tool is of limited use when this is not a true fact and your use of a multi tool actually limited by your medical conditionThe suggestion that I don't know how to use a Multi Tool I find quite insulting, Is there an incorrect way of using a multi tool, don't think so, I also don't wring the neck of a hammer. the problem with the multi tool running away with itself is mostly due to Arthritic hands, but all academic in reality as I don't do installs anymore.
How many tiles have a grout line in the middle of them?, it's not easy starting on a grout line when the customer wants a socket in the middle of the tileTiled walls are easy, there is a grout line to start off from,
I've done this too. Works well, especially if there are services behind and you want to be careful!I'd be tempted to try a small hand held router for those cutouts... make up a template that you can screw to the wall in the correct position (in the middle of the hole that you'll end up with). Then with a small cutter, high speed and say a guide bush... you can simply run around the template. I'd take it in depth steps of say ¼" and see what happens.
Maybe it's easier for me as I already have exactly that setup.
I’ve volunteered myself to add a few sockets in this luxury log cabin I find myself in this week.
The walls appear to be slotted beams of say 60mm wide, but with investigation, they’re 15-20mm wood panelling with a glass wool filled void in between.
I’ve got boxes to cut in, with a multi and a new set of blades…. But it’s the cable route that could be a hassle.
All the new sockets are on the same wall as existing, low level points.. so I was thinking drop down to floor level inside the wall, drill through and run along the front of wall at floor level.
I’ll either get real wood beams and cut a slot in the back, and it should look like a skirting board…… or I’m sure I can get wood patterned pvc mini trunking.
