A
Andy B
I was just looking at the Y plan diagram. In a box at the top it states that when there is 230v to the grey wire of the valve the orange has 50v - 150v.
Why is this?
I regularly see ads for sparks with experience in wiring Y plan boiles.I take it Y plan is the wiring configuration?.If i am correct then experience isnt an issue just an ability to understand the wiring diagram?
If you look at the writing above fig 6 , it says voltage reducing resistor or diode, this will be where the 50 /150 v will come into play
Y plan is the configuration to the 3 port valve. Primary pipe from boiler enters the valve the splits like a "t" one side to hot water the other to hearing circuit."Y" shape.
Although I could be wrong lol!
Y plan
Central Heating Systems
Andy B,
stratplus,
