Discuss You don't see much of this these days ... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
It was under the floor of a 1930's house
Doesn't look to bad for its age!
I see TRS twin, and VIR in conduit under floors with regularity round here. Some of it even in service :anguished:
Lead sheath is a bit rarer though.
The less common aspect of that is the copper CPC. More often the lead sheath was the CPC, it was clamped under a 'bonding bar' at each JB to make the system continuous, and tailed to any fitting that needed it. But for extra money you could order the cable with a copper CPC in too.
I have a few junction boxes for lead twin here, unfortunately most are damaged badly from when the old cables were ripped out, not by me I might add! The round box is also stamped Callender. These boxes came from 4 different buildings and the Henley box was wired with lead sheathed singles IIRC. And last photo is some boxes from a similar time.
I had to repair a switch in my Aunts house in Parsons Green the other day, shame I didn't take a photo but the double switch was held in place by two screws in to the wooden back box packed out with some paper, luckily one switch wasn't used so I just swapped the cables over.
I still have this in my coal bunker under the house which I have never bothered to remove,
Reply to You don't see much of this these days ... in the UK Electrical Forum area at ElectriciansForums.net
Looking for some advice and timescale here. I'm not an electrician just a tennet with a housing association. I've been offered top floor flat in a...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
