- Reaction score
- 362
Discuss You know when its not your day! in the UK Electrical Forum area at ElectriciansForums.net
ill be honest marvo, they do actually teach lead welding at college or at least when i was there in 2010/11 as part of the courseI'm impressed you plumber could repair lead, I'm guessing most new-school plumbers couldn't.
don't mention lead cable technics and micc is just show and tell at the college i went toI'm surprised. I was also taught how to do a wiped lead joint on pressurized cables at college. Doubt I could do one now though, I haven't worked on lead cabling for over 25 years.
never trust a gate valve always isolate and drain it instead.I got a call to a 'no hot water' old dear on Friday, stat on immersion failed, withdrew it about 3" and a fountain of water erupted from the stat tube! Panic for a few seconds as I scramble for the gate valve....even more panic when I discover the valve is stuck solid.....10 minutes later and a lot of water everywhere I finally shut it off. Turned out the tube the stat is in had rotted right off and was just hanging on until I moved it. I knew it wasn't going to be my day that's for sure.
that was the first thing i was taught when i did a plumbing course, gate valves always seize even ones that look new and in good condition.
the isolation valves you get on toilets and sinks etc are a lot more reliable
Reply to You know when its not your day! in the UK Electrical Forum area at ElectriciansForums.net
