Discuss Zelio Soft 2 & Encoder in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Done a few small bits on zelio PLC, fairly familiar with them but stuck now...
My next project is to fill different quantities of water depending on a select switch.
I've a water flow metre and connected up to the high speed counter..
Any ideas how to for example set it up so when i select my preset value that i measure the flow and then stop the valve when i reach the quantity. So i want to put in a equation to measure the flow over time running and then stop when i reach value.
Eg... I want to fill 10 Litres of water to a process and it needs to be fresh flow so cant use a buffer and the pressure changes slightly so cant just use a timer.. (Still doesn't work when i fit pressure pressure regulator and timer - Its close but not accurate enough).
Due to the process i want to just use in an inline flow meter
Any help appreciated
Reply to Zelio Soft 2 & Encoder in the UK Electrical Forum area at ElectriciansForums.net
I have a Zelio PLC installed on a machine with an electronic CT (0-10v) to read the value of current used by the machine motors. When the value...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hi all, As an electrically illiterate person I've found a lot of the posts on this forum helpful when fixing things round the house. I was...
12K
At our church, one of the things I've done is sort out the heating wiring (as best I can for now). The schematic is as shown below. The theory...
