E
Essex_
It has it's place as long as the appropriate glands are being used. Definitely not an SWA replacement. Next you will be saying FP200 cannot be classed as having an earthed metallic sheath either.
SY is meant to be a control cable, the outer serving is not meant to be used as a CPC, it has a core for that, the outer is actually a screen/shield.
nit picker! lol.
I am aware but things move on. I have read some threads on here where people are using buried FP200 to get away with not installing RCD protection. I almost fell off my chair when I read that. Turns out the cable can NOW be used for that (I personally would not though). FP200 certainly was not designed for this purpose either. Things change. I personally only use SY for connecting external equipment instead of standard flex cable.
I am not aware the covering of FP200 can be used as a CPC or be really classed as an Earthed metallic covering in that context either, there is flexi-shield that complies to that definition, of which the BS number escapes me for the moment.![]()
The foil in fp200 is an earthed metallic covering and does comply for protection with regards penetration by metallic objects. This information is in the data sheet.
Gobsmacking
We in the posh North East would say "Pedant". Not only does it sound "posh" but it is also more economical - using 6 letters instead of 9 and one space.:laugh:
sy isnt uv rated thoughI am aware but things move on. I have read some threads on here where people are using buried FP200 to get away with not installing RCD protection. I almost fell off my chair when I read that. Turns out the cable can NOW be used for that (I personally would not though). FP200 certainly was not designed for this purpose either. Things change. I personally only use SY for connecting external equipment instead of standard flex cable.
What is? The fact that the foil layer is compliant or that someone has actually checked the data sheet and not just made assumptions based on their opinions
Why wouldn't it be?That the foil layer is compliant.
