J
jonny705
Another question - :smile5:
When did the use of loop impedance testers first come about?
I tried to google it , but cannot find a definite answer, came up with an LCR meter though?
So how would you know the Ze before they came freely available and I guess affordable - just by enquiry at supplier?
And therefore would you have just used a resistance meter to calculate Zs, and when did/ would they have been used within the industry- i.e. how long ago ?
Also I/R testers , when were they first introduced / mandatory?
My friend gave me a yellow Robin analogue tester years ago when he used it for fixing white goods,
but that was age ago!
Earliest reference I have to a loop impedance test is in a book from the 1950s
Earliest reference I have to an IR test is a book from 1939.
Occasionally you see wooden cased loop impedance testers made by clare on eBay,
These testers have been around for a long time, when I first started out I was introduced to a wind up megger, the faster you wound it the more dc volts you got out, we used to easily get 750 volts! A favourite trick was to charge up a metal bodied condenser (the ones fitted across the contact points in a car distributor) and then you'd chuck it to some unsuspecting victim who'd then catch it, this always resulted in a 'small' electric shock as the fly lead would whack the back of the hand, happy days! As for the loop testers I remember we were given digital versions of them when the 15th edition was introduced in the early eighties.
A 60w lamp and two lengths of wire
Add a bell and battery set to that.
although I used to have a 15w Pygmy lamp in mine.
loop testers were around in the 80s....the firm I did my time with had one between 14 Sparks and 7 laddies!
it used to come up with an overheat when it did too many tests which wasn't many tbh
As an apprentice the only thing we used was a Ductor for dead tests. If you consider each plants N→E link was connected direct to the plant MET, it wasn’t a big issue.
I have used RoB’s lamp method more than once.
It's not something I've done, just something I've seen at talked about.
I'm not that old! Haha
