O
Octopus
OK guys & girls...
yesterday I swapped out some knackered under cupboard lights for mains powered 3W led lights (TLC code KB UCLED4) - they looked good and the customer was happy....
until last night and now they are saying they are too bright!
So - there is no way to accommodate a transformer, so the units need to be with integral driver!
Ideas all?
not electrical but you can get some led light gel stick on stuff from stagedepot to soften the light,comes in a range of shades and colours
are these LEDs dimmable?
Don't they usually come with two different pairs of mounting brackets? One where the light points to the worktop and one where the light will be pointed towards the wall behind, rotating the fitting 90 degrees and throwing less light out, in effect. Especially with granite worktops, they light up rather bright!!
Already done that on the install, so they are behind the (small) pelmet.
...A bit heath robinson,but you can get a yellow lacquer,which is heat proof,for touching-up lamps/lenses on vehicle indicator assemblies.
If not,sounds like a live with it/change it discussion :sad3:
Hum.... yes - I have read on another forum, one I mustn't Talk about, that people mentioned that LED's get dimmer with use - not sure I concur with the latter...
I can't imagine the customer being too happy about a soloution which only lasts 8 months!
Plus how much are LEE going to sting them for that stuff? Normal gel is bad enough!
