Hi any off you guys using these looking for any sort of feed back , seems a descent product , or do any of you use something else ?
For dot n dab that looks like a complete waste of time and money when you can just drill into the block and rawlplug it as usual.
For a stud wall I can't see me rushing out to buy any as there are plastic rawlplugs or worms designed for plasterboard that work perfectly well and for anything that needs serious fixings it'll probably want a nogging fitted anyway
I see these grip it fixings on dragons den...peter jones pulled the radiator off the plasterboard wall.
Don't bother, they are expensive and difficult to install correctly every time!!
I used them last week, the builder I was working with had some. To be fair the brown size are better than the red. The yellow ones... well unless you have fingers smaller than a child and the touch of an angel forget it.
For the red ones you have to drill a 16mm hole first, then push the fixing into the board tapping it into place until the blades at the rear are clear enough for you to turn them using a small flat head screw driver.
This all sounds easy but in practice not so simple. If you knock them in too far they just fall out behind the board and if you are not far enough the blades won't turn. When you come to turn the blades you have to be careful not to press too hard or its game over and the fitting falls out again behind the board. Oh and if you press on too hard when installing the fixing screw its game over yet again! Basically if you don't get it right first attempt then it will cost you!
Obviously on a dot and dab wall they won't work where the spots of adhesive are.
Once in place... they grip quite well but no better than cheaper simpler fixings available.
This is my personal opinion and I wouldn't want you guys wasting you time or hard earned money on a novelty product.
Another for dry line pro. Fixed my tv to the wall and honestly felt it would have taken all my weight easily
Never even heard of the dry line pro either seems a great idea also and proven as well it seems , it takes ages for new products getting to wholesalers this neck of the woods , it's all old hat for you guys when it's new to me
