Yep, cheers for that. Very useful stuff.
There have been quite a few sarcastic responses to this, for obvious reasons. If the OP has to ask such a question then the only conclusion is that he needs to get a spark in to do it. If I was to be more useful I could have made many suggestions but there is no point is there? I wasn't inferring anything about your competency at all, I think you missed the irony.
that reminds me. time to wake the missus up. there's a tub full of ironing to be done.
Me and GO both - I missed the point of your response too. As for the 'if he's got to ask he needs a spark' - I've asked loads of questions on this forum, perhaps I should get a job flipping burgers instead.
don't think with your knowledge to date that you would need to ask a question as per the OP. as far as i have read your previous posts, any questions that you , personally . have put to the forum, have been sensible, well thought out posts commensurate with your trainee level. respect.
Cheers tel - but my point is I only ask questions in subjects I'm not exactly competent in, otherwise what'd be the point in asking questions?
The OP apparently has a degree in electronics, so I'd assume a certain level of competency exists with him? He might have an idea how to do it already, but perhaps is just seeking advice as there may be a better way - for example he might have intention to use a JB but then gets advice to use a MF fitting. I guess I just don't agree with the attitude 'if he's got to ask then he shouldn't be asking' - statements like that are a generalisation that applies to more members than just the 'incompetent' OP.
agreed. sometimes posts are worded poorly, giving us the impression that the OP is thick, but on the other hand, some of the replies are either elitist or a put down. it can be easy to misinterpret a post on a forum as opposed to a face to face query. if in doubt, i generally give the OP the benefit of the doubt where a question may seem silly,just because of the way it's worded.
Exactly tel and I think others have done the same - the OP has had a wealth of advice as well as a polite message that if it is out of his competency level to get a spark in. Just the elitist (perfect expression I think) replies apply a sweeping statement that applies to DIYers, trainees, and seasoned sparks alike.
'If you need to ask you shouldn't be asking' defeats the point of having a forum on the subject.
SBO, ok, obviously I did this miss the irony. My recommendation to the OP was to get a spark in, highlighting the fact it is a small job, which will hopefully encourage the OP to get it "sorted properly" !
another one wet the bed, then?
As far as I can tell from the OP's profile, he or she has no qualifications as an electrician nor is a trainee. We have no idea of the OP's skill base. The OP asks a very rudimentary question, and offers no suggestions as to the possible answers.
I've seen various similar threads in a similar vane (how to install a luminaire to an existing ceiling rose e.g.). Most of these people have been advised to employ the services of an electrician or the post has been moved to the DIY section.
Just because the OP has a degree in Electronic Engineering, I do not see why that advice should change.
with the circuit isolated, take the cables out, pull back under floor, join with wagos in an enclosure. if they won't pull out, then cut under floor and strip and join as previous.
Needs to be a maintenance free joint or connector under floorboards (not easily accessable) as Wago’s are not tested and registered as suitable for maintenance free joints (although Wago’s with a suitable strain relief enclosure are as good as any maintenance free joint in my opinion).
I agree with Tel, you personally do not ask advice for such rudimentary and simple tasks. Surely this forum is for Electricians who may have unusual or more complex issues they wish to DISCUSS. As is so often the case our OP has not done so. I do not think the forum is supposed to be a step by step guide to doing something as simple as removing a socket from an RFC, wherever it might be.
Why has it got a DIY section then?
