Discuss Incoming tail retaining clips in the UK Electrical Forum area at ElectriciansForums.net
Does anyone know where you can buy clips for the incoming tails like the DNO use (figure of eight design)? If not, what do you use to hold them back (SWA glads)?
Sent ... using the force!!
do you mean for outside the CU? can you not use cleats?
I'm due to extend the tails as I need to dropped the CU by 1.5 metres (from above door to 1350 height for elderly couple). Normally I'd use cleats to hold the tails back, but I didn't know if we could buy similar cleats to the DNO as they have 1 fixing for both tails)?
Like the cleats in this picture?
No 5 cleat opened up with two screws look pretty neat if the earth is raised in middle of bothe tails , in this instance some containment would look better though whatever it may be
Use the force
Sent from my iPhone using Tapatalk
how about sticky back tie wrap holders (screwed on if required) and tie wraps? always works out tidy for me
I would say pretty much always required, especially on anything other than really small cable. They always come unstuck eventually. Daz
I've had these clips from a "Universal meter services" website they usually also sell meter seals, and most other items like isco blocks etc
Sent from my GT-I9195 using Tapatalk
The Ellis products are neat,but need to be of the appropriate size,so you would need a stock of the sizes you may use.
You can get good quality tie-wraps,with an eyed end,which can be used for many purposes,and in the application discussed here,can be "stacked",by reversing one tie,and fixing both with one screw.
They are available in all colours,and nothing screams "----",like all conductors secured by a colour appropriate fixing.
I did a friends, like this,and a few years later,he said he had meter swap due,and would i turn up,to ensure no sneaky smart telemetry was installed...
We were having a brew,whilst the meter dude set up,and i asked if everything was ok in there...he replied "who ever did this,was proper OCD!"
Needless to say,much mirth was had...
Same here, was wondering about best way to clip some tails to a wooden panel. However, got distracted with this advetorial video showing serious cable clip usage:
I can't quite get my head around "relatively low short circuit level" and 70kA used together!
Reply to Incoming tail retaining clips in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
I've come across this incomer, looks like 10mm conductors. The dno has upgraded the meter and used a 100A fuse. So my question is, does this...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
Hi all Quick question - I'm going self employed as an Electrician's mate as from the start of November. For this purpose, I'm looking to get rid...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
