Discuss Incoming tail retaining clips in the UK Electrical Forum area at ElectriciansForums.net
No 5 cleat opened up with two screws look pretty neat if the earth is raised in middle of bothe tails , in this instance some containment would look better though whatever it may be
Use the force
Sent from my iPhone using Tapatalk
Reply to Incoming tail retaining clips in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
I've come across this incomer, looks like 10mm conductors. The dno has upgraded the meter and used a 100A fuse. So my question is, does this...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
Hi all Quick question - I'm going self employed as an Electrician's mate as from the start of November. For this purpose, I'm looking to get rid...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
