FatAlan
Trainee
Supporter
Sep 16, 2016
2,058
1,998
2,688
Surrey
Trainee Electrician
I've advised that they should replace with LED GU10s so got myself a job. Thinking I'd use wagos and the wago light junction boxes.
Why? Get a decent enough replacement and there'll be room enough to terminate both cables in the fitting
Reactions: Leesparkykent
I like these Hylec-APL | Emech Terminals/Accessories | Chassis/Panel Mount Tml/Boxes | DEBOX SL - http://www.hylec-apl.com/Emech-Terminals-Accessories/Chassis-Panel-Mount-Terminal-Connection-Boxes/DEBOX_SL.html
Them downlights look like they are in a bit of a poor state might be worth upgrading to integrated fittings or cans and lamps that can accommodate both cables without the use of a junction box if budget permits.
Edit. hightower beat me to it :)
Just thinking that Hightower. The circuit has two switches on it one of which is a dimmer. Wondering if that would have been affecting the life of the transformers?
Thanks for the suggestions. Will certainly try and connect direct to fitting.
You can pick up Aurora cans and dimmable lamps for around £6 a fitting. By the time you buy a lamp, lamp holder and JB you wont be far off that.
Reactions: FatAlan
Not necessarily, a top notch LED down light such as the eco-star units need a jb as they just have a prewired flex tail
The cut outs in the ceiling are 2.5in / 63mm diameter. They've specified Matt white / paintable flush fit.
and you will probably need to replace the dimmer as well.
Ok. Moving on. Searching for a flush fit or very low profile Matt/paintable white downlight that will fit through a 63mm diameter hole in ceiling. Options seem extremely limited or non existent from what I can see.
How does one expand an existing hole by a few mm. Does anyone produce a jig for a hole saw to keep it central or do I have to invent one?
Stack two holesaws together on the same arbor
Reactions: uksrevivor
Presumably that only works if the current diameter blade sits higher than the new, wider one?
Here's what I do.
Cut a 63mm hole in a spare bit of ply or mdf. Take the round plug you just cut and screw it to a new piece of ply or mdf.
Take care to use 2 screws away from the edge of the round plug. Re drill the pilot hole from the round plug through the new mdf.
Now lift the new mdf and slide it till the round plug drops in the old 63mm ceiling hole. You will have a little movement so just centre it. now secure the mdf/ply sheet with a few temp screws. Then cut through the sheet and the ceiling with the new hole cutter.
That sounds more complex than it is....
Reactions: FatAlan
FatAlan
Trainee
Supporter
Surrey
Trainee Electrician
What do you reckon then?
Electrical Course Trainees Only
FatAlan,
FatAlan,
