telectrix
Mentor
This month's Tel's Tip.
Ever been about to fit some pvc conduit and found you've not got your bending spring?????
Panic not.
Cuts 4 pieces of 10mm GN/Y singles to be long enough to go past where you want the bend. insert into tube , warm tube with hair dryer or friction, bend over knee or whatever method you prefer. remove bits of cable. Job done. ( this is for 20mm tube. work it out yourself for 25mm ).
Why did it need a bend, could the vertical not have been shortened for a 90?
Not questioning your experience Tel, you've got 65 years experience on me!
Upvote 0
the vertical tube is literally only 2" from the corner. the bend is totally horizontal, just a kick out from the wall.
Upvote 0
2" where the elbow is next that big blob of cement. more like 3" further up.and it's the brickwork that's out, not the tube :)
Upvote 0
Only having a jest Tel, must admit I was never great with steel tube but I got by but with plastic I can loop the loop with no manufactured bends.
Upvote 0
unfinished. as the existing 10mm was in the way, i unclipped it. after the pic was taken, 10mm was re-clipped and cable tied to the tube. well spotted though.
Upvote 0
point noted. i'm back today to finish testing so will cut off the cable tie ( there's only one, just above the elbow) .and bang a clip clip on the 10mm.
Upvote 0
telectrix
Mentor
cheshire/staffordshire
Business Name
Telectrix
Tel's Training Tips - Education Tels Way
telectrix,
baza890,
Electrical Courses
