What about the Wi-Fi socket?
It's a RECOMMENDATION ONLY that anything over 2KW should be on a dedicated circuit ie not the RFC.Arse. So what's best practice?
OP, did you purchase the immersion heater/plug top & flex set up, or is it something you put together yourself ?
The moulded plug and flex, where did that come from?
It isn't the best idea to load a 13A plug up to 3kw and I suspect this has been occurring for some time judging by the damage.
I think a re-think is necessary. As its your business, I would suggest employing an electrician, and your set re-designed.
Do you leave the flex coiled up when in use?So how to I safely get power to the immersion? Need to be able to connect and disconnect via plug as it's in a van!
The other chap who I do this with has a less manly flex and although his gets hot, it's not meeting hot.
