Guest viewing limit reached
HappyHippyDad
Supporter
Morning all..
I am about to quote for a cooker hood installation including core drilling for the vent. The fan is 125mm.
I have checked upon the sizes of core drill bits and 127mm is the closest fit. I cant see the 125mm ducting getting through that due to the outer diameter of the ducting being greater than 127mm. Does it fit through?
How much of an impact would it have on the motor if I used a 125mm-100mm reducer for the ducting?
Could I cut a 152mm hole and use a larger vent on the outside wall, also using a 150mm-125mm reducer for the ducting?
Cheers.
Have you measured the outside diameter of the ducting? Surely that's 125mm, not the inside!
I've just measured some rigid 100mm ducting I have Murdoch, the outer diameter is 103-104mm. I'm pretty sure with ducting (unlike conduit) the specified size is for the inner hole, stand to be corrected though? Flexible ducting, although more malleable has an even bigger outer diameter relative to its inner diameter.
I also remember drilling a 107mm hole for 100mm rigid ducting and it 'just' scrapes through.
Doesn't the instructions on the Fan/ducting tell you what size hole is required?
The customer has the instructions Pete but I cant see them being much use in this case as they will just say drill a 125mm or 127mm hole. I'm trying to preempt any problems after scouring the internet and seeing that this is a common problem with 125mm ducting.
Did one not long ago, 125 DIA from fan instructions said drill hole at 130 DIA, all I did was fit a reducer to the cooker hood, add 5mm to ducting size and it will fit
So you used a 125mm-100mm reducer and then drilled a 107mm hole?
No l used a 105 but that was because I had one, 107 will do the job just as good, you just do not want it too Tight on the ducting as it makes it hard to get it in, the cover will hide the hole bit off sand and cerment and rember to drill from both sides not just from one
This seems like the best option but if the the motor is designed to remove air through a 125mm hole will it not be straining to remove through a 100mm hole?
It won't strain the motor (might even reduce the load slightly, depending on the characteristics of the motor) but it will reduce the flow for a given fan speed (as will more duct length or bends). Whether this matters to you or your customer is hard to judge.
A lot of MI will say core size 5mm bigger than ducting it allows for movement and gives you a bit of leeway to set the duct so condensation does not flow back to fan.
Handyspacks as pete999 said saves a lot of making good
A mate of mine, had to route his ducting through 2 x 45' bends and 3.5m of ducting. Still stops his kitchen steaming up.
To stop break of the material you are drilling through
I've never had any break away of material on the exit side when using a core drill.
I guess if you have the drill on 'hammer' you would, but that's not how most core drills are used.
Surely, getting a core drilled hole to meet up accurately when drilled from both ends would be difficult?
Not really drill through from one side until the pilot shows and then drill through from the other side with the core drill engaged, rocket science is not required.
Think it's just the way you are shown How to do things , was always told to drill a pilot hole first then the biggy and go at it from both sides, but that was 34 years ago so things change with time, drill bits have got better and making good is just a bit of silicon
220 x 90 mm is approx 6"
204 x 60mm is approx 5"
lucky these days from what i have seen drill pilot hole, drill in 1" then club hammer, think it is in case they loose to many diamonds or is it too much time i am not sure maybe my age.
Silicon, sillycon or silicone it's all the same at the end of the day, just when I started out was drummed in to me that you do a good job as in Measure twice cut once, drill little them bigger, keep mess to a minimum and leave a good job
I think you are overthinking this a bit HHD. Core your ~105mm hole and use a 125-100mm reducer above the fan. It will work fine. :)
A good tip for hard engineering brick is to core through by around 25mm then stitch drill holes around the circle to speed up the remaining coring.
I sometimes core from both sides, depending on the finished surfaces inside and out. Does make it much harder to use rigid ducting though doing it that way. I tend to core from the outside to the inside, this due to the dust levels.
HappyHippyDad
Supporter
Gloucestershire
Some advice regarding 125mm hole for cooker hood fan please?
HappyHippyDad,
Midwest,
