H
HumbleWorker 91RT
Hi guys and girls,
I am having a slight issue with my multi meter,
its display has randomly flickered whilst on voltage then the continuity buzzer just went off.. and the screen crashed.
I have a feeling it's shorted internally due to the strange behaviour, when I use the rotary to turn it off then back on it resets...
I must also say I haven't had it calibrated since I first got it three years ago.
Anyone had a similar issue?.
Cheers,
HW
Try a new battery
Hey bud,
I've already tried this, still does the same thing only now when I move the rotary switch from AC Volts to ohms/continuity it crashes again....
I don't want to disturb it by opening it up but think that's the only choice right now
If it hasn't been used much then there may be dust/dirt in the rotary contacts. Have you tried rotating the dial a number of times to wear away any surface grime? Can you get into it with some contact spray?
Murdoch - do you have your multimeter calibrated? MFT yes but multimeter?
Hey RPA,
Yeah I've been using it the past week quite a lot so it's usage should of sorted out any sort etc banana ports seem clean and sprayed contact clean on them
