Discuss Replacing smoke alarms in the Electrical Tools and Products area at ElectriciansForums.net
Steve T
Hi
I need to replace two smoke alarms in my house, one is in the hallway and the other on the upstairs landing. They are interlinked, and 240 volt powered.
Which type of smoke alarm would be best for these places, and do you have any suggestions of any particular brand of smoke alarm to use? (They don't need to have the terminals on them as there is a back box in the ceiling)
Thanks for any advice
Go for the ones which have the 10 year lithium batteries,(ei161). you will be replacing the 9v batteries when they run out in the other units, and cursing at them when they are bleeping in the middle of the night
Aico
2 x optical
Don't be fobbed off with the cheaper ionisation units.....
There are certain (rare) occasions where ionisation detectors should be fitted instead of optical detectors. For a hall and landing I would agree with optical though.
I must say I'm surprised that England still allows a pathetic LD3 system in domestic new builds.
Why you are protection the escape routes in a dwelling, same as and L4 in commercial situation. Minimum requirement.
Things have moved on elsewhere though. In all of Ireland (both north and south), and I believe Scotland, the requirement is for an LD2 system. In fact in the south with IS 3218 the requirement is expected to exceed the LD2 system once the Building Regulations catch up.
Apart from an added heat detector in the kitchen or high risk area, only the escape routes are still covered under LD2
If there is a risk in living room say open fire then yes....but this is where most of built up England do not have such risks. So the standards are just the same under part 6 but not required. Classic would be solar panels and control in loft areas, now this would class as a risk for detection within roof spaces, something missed alot in England
Hi
Aico lithium :)
Reply to Replacing smoke alarms in the Electrical Tools and Products area at ElectriciansForums.net
Hi all! This weekend we have an offer on 8 of our most popular Smoke, Heat & CO alarms from trusted brands! Don't wait too long as these offers...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
