R
Richardson Andrew
Hi everyone,
Possibly a stupid question, I am looking at changing from a full time job to becoming a self employed electrician. I have my C&G Level 2, Level 3, and my NVQ3 +am2 (gold card).
Apart from the obvious insurances, is there anything else I need to undertake work?
I'm confused as To what I need to sign off my own work. Do I need to be registered with a governing body (NICEIC , NAPIT etc) or can I just fill out a test certificate and give it to them? Or do I have to let the local authorities know? I'm assuming they charge?
TIA
You would need to be registered with a scheme if carrying out notifiable works under Part P.
For commercial and industrial scheme membership is not required however a lot of customers will prefer it as this provides some form of insurance.
So to carry out any minor cert or install cert I have to be registered with a governing body to be legit, I can't just fill out a text cert and give it to them and inform local authorities?
You could do it that way but LABC will want lots of money from you so from a business perspective it makes it cheaper to be scheme registered.
What's recommendation for a governing body? NAPIT? I need fairly cheap but reliable, I'll only be a 1 man band
This appears to be very much personal choice, I chose Elecsa (which is part of the organisation that includes NICEIC) which was very good value for money.
If cost is your primary factor then I would certainly recommend Elecsa as a good place to start
Hope this helps
Don't get certification mixed up with notification.
The wiring regs require all work to be certificated after testing.
The building regs require certain work within dwellings to be notified.
You do not have to be in any scheme to issue a BS7671 certificate. Schemes are only to facilitate notification which is separate and additional to the test certificate.
Have a read of the part P document.
Electrical safety: Approved Document P - GOV.UK - https://www.gov.uk/government/publications/electrical-safety-approved-document-p
It is a legal requirement that work carried out in dwellings complies with Bs 7671, and that certain works in dwellings are notified to building control. The only cost effective way of notifying is through one of the schemes.
Most work will require an EIC or MW cert issued to the customer, and you will then notify building control (if required) through your scheme.
The term 'signing off' is often used but is rather misleading.
So does this mean if I done a kitchen install and produced a certicate, all I'd have to do is notify local authorities? No governing body required?
If you go down that route then BC must be notified before work commences and will then relieve you of several hundred pounds to 'sign off' the work. You will still need to issue the appropriate cert to the client.
As already stated, the ONLY cost effective way is through a scheme such as ELECSA/NICEIC/STROMA etc. Failure to comply is breaking the law.
Sorry I sound uneducated lol, what do you mean a part p scheme? Do I need to do the part p course even though I'm a gold card electrician ?
ELECSA are good and their technical help especially good. However if you want cheap then STROMA is your future I suggest. You could always move elsewhere at some future point - unless they change the rules.
You'll need to provide evidence of good practice with an example installation you've done. Any of the web pages will give you the list of requirements for certification.
