M
Mighty Grimm
Hello, I’ve been asked to rewire an old warehouse and, having had the SWE folk install an isolation switch, I popped in a split CU and have been happily running new cable hither and yon.
However, my C&G Quals were many moons ago and I’ve been fiddling about with telecoms ever since, so my knowledge of wiggly amps is sketchy to say the least (and yes, I do intend to have my work checked by someone registered).
So, if you’ll forgive some numpty questions:
Do the tails to/from the CU need to be crimped?
I’ve been asked to run 10 mm T&E into the CU - the cable won’t fit the punch outs, so can I break out the L/N/E and feed them in separately or do I need to butcher the CU?
Many thanks for any help
