Dave OCD
Mentor
I've managed to confuse myself a bit, I have to connect up the above boiler with 2 zone valves. Now the 'external controls' link is low voltage in the boiler and this is connected to the built in timeswitch for heating, I have 2x 2 port valves [upstairs/downstairs heating zones] and Honeywell room stats which don't have separate volt free contacts.
So I'm thinking of fitting a separate single channel programmer [leaving boiler timer permanently on] with mains out to the two valves[brown motor drive cores] via the stats and using the grey/orange cores in the valves as volt free contacts connected in parallel to the boiler control pair. [Rather than connecting the switches to mains as normal] .
What are your thoughts ?
I think this would be simpler than mucking about with a relay, replys would be very welcome. :)
T6360 I think Lee. [Old school stats]
yeah not going to work with the internal programmer. Options are change the thermostats or use an external programmer and take the volt free switching through the grey and oranges of the valves as you say.
Thanks for confirming that Lee, can't really change the 'stats as only got 3c and earth to each one. :) I can't really see how a relay would work with this setup anyway.
Thanks Lee , how would I then get the mains to the motors on the valves though ? It's possible that I'm being dim here.
Actually thinking a bit more I could even use a 2 channel programmer for separate up/down times- would probably just cause more confusion for the end user though. :)
Dave OCD
Mentor
Cornwall
Business Name
Hendry Electrical Services
Ariston E-Combi with 2 zone valves.
Central Heating Systems
Dave OCD,
Dave OCD,
