or the could ring up dynamo.hi the double socket is separate to the cu ,ive got an insulated screw driver ,my thoughts are cut a hole in a new piece of ply cut ply in half suspend cu from celling joist
I never seen a c/u board being levitated in mid air !
now where should I start!i have done a little electrical work replaced old style wire fuses for them plug in rcds ,water not a problem gas not much of a problem got sqeeze offs and you can see water leaks and smell gas but electric is different if i could isolate the supply it would be no problem ,just waiting for buzz to reply to this![]()
you has well .thanks mate have a good new year![]()
