C
Chris86
Good morning All,
Sorry for posting another sub main question but i have searched various posts and cannot find a definate answer.
I need to install a submain out to a brick built outbuilding which will be used for injured/unwanted ferret rehab. Building has no extraneous conductive parts and main supply is pme.
My plan is 32A rcbo in house consumer unit, 9 metre run of 6mm t&e through floor joists to galv box on outside wall. 6mm 3 core SWA from galv box to outbuilding 11 metre run buried under footpath and them fixed to garden wall. 2 way CU in outbuilding with main switch, 16A supply for sockets and 6A supply for lights. All in galv conduit to make it ferret proof.
My question is, would i be better off having an mcb at the house end and rcd main switch in the sub board? I feel the submain cables would be better having rcd protection but as i can comply with greater than 50mm deep at all points, i am starting to doubt my plan. Any thoughts?
ATB
Chris
ATB
Chris
