Hello,
Had a call-out today for a lady who was concerned about 'flashing' lights throughout her house. The 'flashing' happens about once every 10 minutes, and the lamp essentially goes off for a split second. The issue happens across both of the lighting circuits. I've checked at the board and within the lighting JBs in the attic for loose connections but everything is nice and tight. The only thing I can think of is that the cheap halogen GLS lamps in use are causing this to happen, although I'm having trouble thinking of a reason why they would do this (if they even are).
Any thoughts appreciated!
it was not close encounters was it?
I thought it might be to do with a load somewhere else too, but the 'flashing' occurred with just the lighting circuits energised. RE the table lamps, no - only the ceiling lights which had the Halogen GLS lamps in them.
In parts of Southampton the supply sometimes 'dips' when it's fed from different networks or something; apparently when the H&S manager is sitting at home and the lights dip he knows he's going to get a call from the factory because certain machines have stopped.
I have come across this problem before,
It is usually caused by poor connection between the lamp and base.
these lights produce considerable heat, and the bases run hot
So they deteriorate, this can cause intermittant contact.
the only long term solution is to replace the base and the lamp,
as it usually causes damage to the pins and there coating.
Bases are usually easy to obtain and replace.
Edinburgh
Cheap Halogens Occasionally Flickering
lumenmachine,
lumenmachine,
