Discuss Cheap Halogens Occasionally Flickering in the UK Electrical Forum area at ElectriciansForums.net
Hello,
Had a call-out today for a lady who was concerned about 'flashing' lights throughout her house. The 'flashing' happens about once every 10 minutes, and the lamp essentially goes off for a split second. The issue happens across both of the lighting circuits. I've checked at the board and within the lighting JBs in the attic for loose connections but everything is nice and tight. The only thing I can think of is that the cheap halogen GLS lamps in use are causing this to happen, although I'm having trouble thinking of a reason why they would do this (if they even are).
Any thoughts appreciated!
Replace a lamp with a decent brand .................. did you check the incoming tails at the CU and the meter and the head?
Is there sizzling or crackling from the DNO head?
it was not close encounters was it?
I thought it might be to do with a load somewhere else too, but the 'flashing' occurred with just the lighting circuits energised. RE the table lamps, no - only the ceiling lights which had the Halogen GLS lamps in them.
In parts of Southampton the supply sometimes 'dips' when it's fed from different networks or something; apparently when the H&S manager is sitting at home and the lights dip he knows he's going to get a call from the factory because certain machines have stopped.
Reply to Cheap Halogens Occasionally Flickering in the UK Electrical Forum area at ElectriciansForums.net
We have two units (with separate meters and panels) in a residence that underwent a major renovation about two years ago. During the renovation...
This is in my home and none of my neighbors have this issue. Two of us get power from the same wire coming from one electrical pole. He says he...
Hi, I think I need to state that I'm a DIYer? I have A-level physics and tinker with vintage audio gear but I'm no professional electrician...
I have several rooms of downlight fittings with non-dimmable 5W GU10 mains AC LED bulbs, making about 150W total. They run off a single 1.5mm twin...
Got an emergency call out from a very worried old lady the other night - the power at her apartment had gone off and the kitchen light was...
6K
