Ib≤In≤Iz
A non maintenance free JB under the floors is NOT compliant.
Think you mis-understood my post...
No I was backing you up Murdock.
OP Said that the Standard round 4 way 30amp junction box are compliant.
I think?
Plaster and laff???Hi people how much would you quote to add 4 new sockets?
1st one in living room at shoulder height. Skirting and floor boards will need lifting. Chasing up the wall and sheaving.
2nd in kitchen. Slight chasing in wall and then chasing up back of units to ceiling level all most.
3rd in bedroom into brick wall at skirting height. Slight bit of chasing out of wall and sheaving. Lifting skirting and floor boards up.
4th into a studded wall which is plaster and laff. Socket to go in at head height and chasing down the wall through a fire break then into the floor.
Any advice will be appreciated, thank you
Less mess I assume.
A lot of newbies don't realise that cables under floors don't have enough "give" in them to cut and add a junction box!![]()
They are compliant thanks murdoch.
Yes, why not? if you fit one in an accessible location, nothing wrong with that, if you can locate a RFC leg I could show you how to spur from that loction without even cutting the cable.Do people still use 30amp junction boxes?
Yes, why not?
I added that caveat and reposted Mate, you must have answered before I edited my post.Not under floorboards ....................... or anywhere they are not accessible without any tools
Not much slack about an inch.Yeah, useful if you don't want to cut a cable I suppose, not enough slack or something. Fair enough.
Still hoping for an explanation ......................
No doubt you’d do it live too?Yes, why not? if you fit one in an accessible location, nothing wrong with that, if you can locate a RFC leg I could show you how to spur from that loction without even cutting the cable.
... if you can locate a RFC leg I could show you how to spur from that loction without even cutting the cable.
