I know what you're saying but with a torque screwdriver you "know" without doubt that you've followed the manufacturer's instructions to the letter (or number).
Depending on the calibration accuracy of the tool used :grin:
After looking at the extortionate prices for what is in essence a glorified screwdriver i think i might stick with the trusted technique of swear tight. I have thankfully never had a connection come loose or caused arcing due to a loose connection so im going to give it a miss.
Seems like another scam within the industry in which scare mongering is used, thanks for the input guys but im being a tight git atm.
I only bought mine because I had ended up with a credit note at a supplier due to a customer changing their mind and leaving me with a load of accessories.
What I thought was tight, turned out actually to be... not so much when I used the torque driver. Even the factory connections were quite a way off the mark.
The interchangeable blades... typically I put the large modulo driver bit on and that's it, it doesn't pretty much all the screws in the board. Print a label and stick it on the inside of the board with the torque settings and then when everythings connected, go over everything and give it a once over with the torque driver.
speeding in his lotus/subaru/lambretta?
