the cause is obvious.the 3.5mm pins have not been fitted.I replaced a cooker switch 2 days ago where the load side neutral was burnt out.
.Naaathe cause is obvious.the 3.5mm pins have not been fitted..
Maybe there are too many sparkies using a torque screwdriver to terminate connections?? It's a ridiculous trendI've often seen the neutral conductor burn out at the connections points on high kilo wattage heating elements. You find that the connection has to be very sound and low resistance else the slightest increase in resistance seems to rapidly increase the temperature of the connection, especially common on the neutral side. This is something I've pondered over on many occasion. You may have noticed this on electric showers and such in the domestic sector and things like kilns and such in the commercial sector. Why the neutral side seems to be more susceptible I'd like to get a better understanding of?
So you'd advocate ignoring manufacturers instructions because the majority of terminations come with a recommended torque setting?Maybe there are too many sparkies using a torque screwdriver to terminate connections?? It's a ridiculous trend
I've given you a dis-agree, even though I assume you are referring to the use of impact drivers used for fixings etc... There are situations (as mentioned by Marvo) where torque setting is important.Maybe there are too many sparkies using a torque screwdriver to terminate connections?? It's a ridiculous trend
Why have you assumed I meant impact drivers? If I had meant to type impact drivers that is what I would have typed. Confused.comI've given you a dis-agree, even though I assume you are referring to the use of impact drivers used for fixings etc... There are situations (as mentioned by Marvo) where torque setting is important.
I advocate using all the tools you have at your disposal,manufacturers instructions,common sense,experience....etcSo you'd advocate ignoring manufacturers instructions because the majority of terminations come with a recommended torque setting?
Then I have misunderstood your original point, my apologies.Why have you assumed I meant impact drivers? If I had meant to type impact drivers that is what I would have typed. Confused.com
I referred to torque screwdrivers as a ridiculous trend because firstly there are issues regarding the validity of certain manufacturers torque drivers and also a torque driver is going to need calibrating periodically if you want to be sure it's working as intended,who calibrates them and how often? I would much prefer the old electricians method of terminating cables . T.W.A.T.Then I have misunderstood your original point, my apologies.
I'm just as confused why you think using torque screwdrivers is a "ridiculous trend"? Like any tool they can be abused, but used correctly can be a useful bit of kit.
Whilst I agree with every word of that have recently purchased two, one for me and one for the old man.I referred to torque screwdrivers as a ridiculous trend because firstly there are issues regarding the validity of certain manufacturers torque drivers and also a torque driver is going to need calibrating periodically if you want to be sure it's working as intended,who calibrates them and how often? I would much prefer the old electricians method of terminating cables . T.W.A.T.
Tighten
Wiggle
And
Tighten
Torque screwdrivers are excellent in theory but in practice are a waste of time and potentially dangerous and they have already been blamed for many of the overheating terminals that have occurred on smart meter upgrades as the energy companies insist on their 'highly skilled operatives ' using torque drivers. Basically when you see someone prancing around with a torque driver the first thing that comes into your head is 'all the gear no idea'.
No disrespect intended to anyone or their torque screwdriver.
