Square head bolt - correct term
here you go. square heads. :
images
German Army sparkies???
almost went for the security screws, the ones that will only turn clockwise in but cam out if an attempt is made to remove,
Haha Tel!
my favourite screws, those!
Many deacades ago the square socket screws were quite common in boatyards...those producing bespoke yachts, I mean.
Had to make sure the "slots" were tightened up just right, so they were "all square"!
Naturally, the modern square drivers are not a perfect fit...
are they like wall-dogs? or do they need plugs?
No, they still need wall plugs, but when you place a screw on the end of your screwdriver, you can literally do a somersault with it and it won't fall off.
Brilliant for screwing into ceilings etc.
They're colloquially known as screwlux
