For a Job I need to extend and relocate 3x SWA cables, after inspecting the cables I first concluded that they were 25mm 2core, after then comparing an off cut of 25mm 3 core to the existing cables the 3core appears the same size or even possibly smaller, I am now pondering if the existing cables are 35mm 2 core,
I only have the one picture at the moment but will be able to post a picture of inside the enclosures in a couple of days, all cables fit into a standard 60947-3, would 35mm fit into one?
Any help appreciated thanks View attachment 44606
What on earth is going on with those clamps on the SWA!!
As above if you asking about volt drop, how far etc.
Just out of interest, will there be another phase supplied or are you planning on splitting one of the existing?
Unsure at the minute what the DNO will be supplying, two of the homes are much smaller than the 3rd and 4th.
which are the smaller. barret or sherlock?
