el-handbag-013-ect-011-el-handbag-013-ect-011-hand-held-bag-original-imaf7cypjxt6fdha.jpeg
I've never replaced halogen MR16's etc with the LED equivalent, mainly 'cos the client was ----ed off changing the transformer, and the can had seen its sell by date. But I guess some might work.
But using old stuff, you'll end up getting the call, its ----ed up after your visit, so why bother.
Sorry about the language.
I've gone to do small jobs and people ask why their new LED is rapidly flashing on an off!
One was a University Professor (physics) - when I explained that older transformers often have a minimum load he instantly recognised the problem
Funny world
I never fit 12V leds unless its the only option ........... 230v units are the best answer
Also, the fitting may need replacing with Fire-Rated ones, so a combined fitting and 240volt LED may be the best / cheapest option?
I think they "may" need to be Fire Rated as the ones shown in the OP's original photographs are open backed and there maybe accessible living accommodation in the room/s above that ceiling. Remember a plaster board ceiling has more then one function; the original one was to stop the transmission of noise, but more lately it is to stop the spread of fire.
Remember! Fire-rated fittings are only necessary where a fire compartment has been breached ( by someone making Swiss cheese out of a ceiling for downlights).
Ceilings in normal dwellings are not fire barriers and do not have any quoted fire resistance. It’s not needed, it’s pointless.
If it’s a double thickness plasterboard ceiling, or constructed from the pinkun then it’s s different matter.
Take a look at a standard house, there is a huge hole between the downstairs and upstairs. The staircase. That’s the bit to worry about.
I can personally vouch for that.
Fire started downstairs and burnt its way up the stairs.
All that happened with the downstairs ceilings was the lining paper peeled away.
The plasterboard is put up not to just look nice, but protect those wooden things in the ceiling. And now with the 18th, those plastic cable clips.
You've told us about the stair thing before, thats why we have doors.
Bit of a thread resurrection but been doing a trade counter straw pole on this one and the findings are that no-one seems to know what the he'll I'm on about.
They just sell MR16 LED lamps, never had any back and don't recommend transformer replacement.
Now, the caveat is that your average trade counter staff is not always that knowledgeable but you'd expect they'd remember getting a slew of returns.
In my reactive maintenance role it doesn't really matter that the lamp might not last, typically it lasts longer than the staff, typically they last longer than the halogen they are replacing.
I can see why the domestic lot would rather replace for GU10s and it make sense.
Roger le Badger,
Shoei,
