ImpededLoop
A potential customer has an external light control system originally manufactured by Timeguard. There's a controller in the loft space which has a 2 core cable to each PIR which seems to be a bus wire. The PIR's are now failing, part number: SL099. I've found them on Google but they are discontinued and nobody seems to have any available.
http://www.timeguard.com/media/266/SL099_Instr.pdf
Does anyone know anywhere that may stock them? I know it's more likely that the system will have to be replaced. Is there a similar system that uses a two core cable to link the PIR's to a central controller?
There was a similar post on here in 2015 which got not replies, but I thought that it was worth a try
there are similar systems with PIRs on 12V. Voltek and GED.
This is only thinking outloud, but would PIRs intended for alarm/security systems be compatible?
no idea sorry it's never missed a beat in 21 years,try smiths ? i can get you some info off controller in morn if i can
if you google smiths 12 volt security system it bring this site up, in 2015 the famous tazz replied with full instructions that a gjd opal will fit it, the piccy is same as our system
Many thanks for looking it up. Unfortunately the system that I was asked to repair is a two wire system.
